It is currently Sun Aug 24, 2025 3:17 pm
 Post subject: Cuuting Wood Bindings
PostPosted: Sun Aug 11, 2013 9:20 pm
First name: EddieLee
Last Name: Brown
I have a nice Bubinga board that I want to use for guitar bindings. What is the best way to go about cutting these.
_____________
EddieLee
PostPosted: Sun Aug 11, 2013 11:47 pm
First name: nick
Last Name: dingle
band saw. thickness sander.
PostPosted: Mon Aug 12, 2013 1:52 am
Last Name: Beaver
City: Lake Forest
I usually use a fairly thin kerf saw blade on my table saw. They come out clean so I don't need to do much thickness sanding. Bandsaw is ok also just need a little more sanding
Joe Beaver
Maker of Sawdust
PostPosted: Mon Aug 12, 2013 10:23 am
Last Name: Brown
Thanks, Good tips. Does it matter if they are quarter or flat sawn?
_____________
EddieLee
PostPosted: Mon Aug 12, 2013 1:02 pm
Last Name: Beaver
City: Lake Forest
I usually use pau ferro, east indian rosewood, maple or ebony. I haven't had a problem if it is not quartered.
Joe Beaver
Maker of Sawdust
PostPosted: Mon Aug 12, 2013 10:09 pm
First name: Randolph
Last Name: Morris
The thickness of bindings do not lend themselves to movement. It is more of is an aesthetic issue. If it looks good, go for it!
PostPosted: Tue Aug 13, 2013 8:19 am
Last Name: A
Todd Stock wrote:
Diablo blade in table saw...fast, accurate, and no sanding to get to dimensioned strips with good technique.
Todd - I am thinking about cutting some solid linings with my table saw and Diablo blade (which I rarely use) - I respect the tool and don't want to do anything silly with it. I have been cutting and thinning the wood with a bandsaw and plane for linings - but I am unhappy with the result, I want more consistency. My question is if I have a board 3/4" x 6 " x 32" and I want to take slices from 6" width - meaning 3/4" x .07 or .06" slices - how thin can I safely keep pushing that 32" board through the saw ? Meaning my 6" board will be 1.5" wide after I peel off 'x' number of .06 x 3/4" x 32" slices - after 1.5" my push stick is probably too close to the blade - what do you do with the left over piece of wood that is now 1.5" x 32" x 3/4" - leave it for the bandsaw ?
An idea I had was to glue the 6" board I want to use for linings or binding to a sacrificial board that will go against the fence till that last usable slice of my 6" board is cut.
PostPosted: Tue Aug 13, 2013 8:52 am
Last Name: A
so are you re-adjusting the fence by .06 every cut ?
Users browsing this forum: doncaparker and 16 guests
